Old 05-26-2011, 02:24 AM   #1 (permalink)
chris_kraft3
Mr2 - '85 Toyota Mr2 built turbo
90 day: 24.99 mpg (US)
Si - '08 Honda Civic Si
90 day: 32.91 mpg (US)
Chris Kraft Build Thread_Big Turbo car!
Do you think I can make a serious Ecomodded vehicle out of this? (Rhetorical)
I am super excited to show off what I am working on. I have been into cars for as long as I can remember. Sustainability has been something I have admired for a long time also. I drive quite a lot each and every year. For sure I have been driving a solid 20k miles a year per car since 2004. I have always been excited in being able to go fast, but with a small motor. 100+hp per litre is my style.
Now this car i am in process of converting was built for speed. Now it is time for both, for me to be able to go faster and better and cheaper at doing it.
I will have to post up the pictures of what I have done so far. My testing grounds are running between Wichita and OKC on I35. I use the same two gas stations when I travel this trip. My wife goes to school in OKC but I have a mowing business in Wichita. During the spring and fall I driving back and forth weekly. We have a FA5 Civic Si you see in the back of the first picture that can average up to 34-35mpg on this trip. Most of the time it gets 32-33. I had my Mr2 retuned last November for more power from the people that built the motor. I am at 249whp and 181wtq in my 4agz(t)e 1.6l that came in this style of car.
When the car was first tuned I wasn't getting much better than 17-19mpg. That is very low for this car/engine. But first time I launched the car it did a 4.4second 0-60mph. Not a whole lot of complaining you can do with those numbers except the cost. I have a much larger width of tread touching the ground than what the car came with to be able to put down the power. Since I am getting away from so much acceleration I am less concerned with this.
So let's start off with where I have made changes. There are multiple holes in the front bumper that serve no purpose at this time. The turn signals are inset behind the bumper a few inches. There are two holes in the bumper right below the turn signals that serve no purpose. So a theory I had was to fill those holes before I did a run to OKC. Now I'm not one of those guys that does the ABA testing because I am so excited of my gains that I don't want to drop back. I bought two small pieces of plexi and blue painters taped them over the holes in the bumper. I filled my tires with a bit more air 28psi front 34psi rear. I also did the cruising style without A/C (shirt off). I also turned my mirrors inward. Before these mods I was catching around 23.5mpg hwy. Before was with harder acceleration though. Now I had forgotten to account for tires size difference. If my new tires are 100% then my factory would be 94.4% so I take this into consideration now. I have read much on this website to come up with these ideas in the front bumper. With these changes I have accomplished 29.8mpg hwy. I am hella excited about this number.
But I have much to accomplish from this. My mod I have done this week was to kick my tires up to max pressure. 44psi front and 50psi rear. This has made my rolling resistance less, so much that you can feel the difference. I also did a K&N filter cleaner to my filter. Wow it was dirty. The motor can now run on a lower rpm while being able to pull the car. With such large cams in the car it hasn't ever really liked the lower rpm's.
I am planning on picking up a set of factory sized 14in wheels in place of my 17in this weekend. I will do the pizza pan face on them and going from a front tire of 205 and rear 225 down to a factory width of 185. But the issue with this that may be contradictory is that height will be close to factory specs bringing my rpm up a bit while cruising on the hwy. I will have to test the differences on this with an ABA test.
I would like to hear your feedback on my project. Thanks for reading.
