Old 05-26-2011, 07:06 PM   #152 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Got the header attached, spent nearly half an hour grinding the intake flange down to make every thing happy. Attached a piece of pipe to the header, then bought some pieces to a adapt it to the stock exhaust for now.
....never finished writing this, installed the couplers and got everything linked together in the exhaust... And now it smokes. *facepalm*
The struts I bought were advertised to fit mk2 and mk3... Not surprisingly, the fronts don't fit correctly. The mounts aren't correct. Hopefully I can get it inspected with worn struts, because it will take days to work this out with the seller.
