Originally Posted by 379Kcivic
for parts?
I'm so paranoid someone is going to try and sell me a dx or cx tranny just because it will fit.
Then tell them that, tho the CX transmission is the same as the VX, but you don't want a DX or SI, but when you take it in make sure to tell them that you want the correct VX/CX transmission and that with that it should run around 2,000rpm going 65mph in 5th gear, take the car for a test drive before paying them if it is not right then don't pay them, that simple, but be clear with them before you have the work done, otherwise put your zip code in car-part.com and see what your options are to buy, pick it up your self if you want to.
