Old 05-27-2011, 06:41 AM   #72 (permalink)
skyl4rk
Coasting Down the Peak
skyl4rk's Avatar
Toyauto Pickup - '94 Toyota Pickup 2WD
90 day: 36.32 mpg (US)
Versa Base - '09 Versa Sedan 1.6 Base
90 day: 41.69 mpg (US)
Originally Posted by crmears View Post
I do not think that we should attempt to copy the shape of a wing. Wings are designed to use airflow to create lift. The action of creating lift with a wing induces drag.
Randy
Wind tunnel tests are used to determine the wing profile shape that produces the most lift with the least drag, so at least some of wing design is useful as a model for an aerodynamic vehicle. A vertical wing shape as a trailing edge to the RV would be ideal, however it would be far too long.
Have you considered an aerodynamic trailer?
Nissan Versa Aeromods
