I'm a little confused. You specifically asked for 0 degrees here:
Originally Posted by winkosmosis
If you know of a plane that can fly at 0 degrees wing pitch, post it.
then you say that position doesn't make sense...
I'm not sure the normalized position based on the leading edge and trailing edge makes sense.
My point is that this, and most asymmetrical airfoils, make lift at 0 degrees, so it is simply a matter of going fast enough and/or being light enough before you have a plane that can fly at 0 degrees wing pitch.
What do you think is redirecting the air on top of the wing?
