If Bernoulli was that powerful, you could take a thin flat plate, pitch it a few degrees so that there would be no attached flow on the bottom rear-facing side, only the top front-facing side. The huge difference between flow speed on top and bottom would let Bernoulli exceed the downforce from turning the flow upwards.
