Originally Posted by CapriRacer
Just be aware that there are extreme differences in rolling resistance between tires - even of the same size, let alone what the differences in size make. Be careful that you don't draw conclusions without taking into account that there might be severe differences different tires make (meaning make and model of tire).
True, there are dozens and dozens of variables, from manufacturers using the same name on different tires, to them using different compounds on different sizes of the same model. The "new" tires are 8 year old Continentals, sporting an obsolete tread pattern. They're simply cheap test mules which I'll replace with LRR tires if they work well.
On the plus side, I can always fill the worst-testing tires with pure nitrogen, and turn them into the best performing tires  .
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
