Old 05-28-2011, 01:23 AM   #3 (permalink)
mwebb
mwebb's Avatar
no nickname , it's just a car - '04 volkswagen golf tdi
you will not like it
EGR valve fouls the fuel rail so I have to swap it for another.
How do I hook up that extra wire from the wide band O2 sensor?,
the EGR valve does not and can not "fouls the fuel rail "
so kindly add great detail to what it is that you are attempting to state .
and
you will need to use a 4 wire 02 sensor that was designed for your system , your ECM and harness can NOT be retrofitted to use
an AFR sensor .
5 wire sensors are NOT 02 sensors they are Air Fuel Ratio Sensors , they do not and can not interchange
