As per "fouling the fuel rail" that comes from the mechanic who installed the exhaust manifold and P07 ECU, I'll have to check it myself.
I thought all models of the 92-95 Civics had identical wiring harnesses, therefore the wiring for the VX 5 wire sensor.
I'm sure I can rig up the VTEC-E to run in my CX, "your ECM and harness can NOT be retrofitted to use an AFR sensor"- I really don't want to believe that, I've got the right ECM and as I said I was told that all 92-95 wiring harnesses are the same, just different wires used for different models.
Thanks for your response and I hope you're wrong.
