Well if your idea was just to shut off the injector to that cylinder manually, I can see another issue. The air being drawn in to the non-firing cylinder would then be forced out into the exhaust, the O2 sensors would read 4 cylinders worth of air and only 3 cylinders worth of burnt fuel, and the computer would think the engine is running way too lean and richen up the 3 cylinders that were still firing. At least I think that's what would happen, though I may be totally wrong!
"Don't look for one place to lose 100 pounds, look for 1600 places to lose an ounce." - Tony DeFeo
