Old 05-29-2011, 02:05 AM   #6 (permalink)
hondaguy72
Enthusiast
Just an FYI it's not a direct swap, and most of those rear axles are drum brake setups, so you'd have to do some brake mods to get the bias correct. T-bird turbo coupes have the disc brake axles, but come with 3.73 gearing. It appears you have some options for rear gearing from other vehicle sources too. Not sure if there are gears tall enough for your stock differential readily available. Nice job on the swap!
