Old 05-29-2011, 11:51 AM   #28 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by wyatta4 View Post
I'm confused as to what kill switch to place in my car :/ .. Any help?
Edit: I mean, in which way should I do it? The first or second guide? Or neither?
Easiest for you is an injector kill. There is a single power wire that feeds a resistor box, it's the only wire on the box that is a different color. The box is a finned aluminum case mounted on the drivers strut tower.
Switch inline with the different colored wire will kill power to all four injectors. This assumes you mean the CRX.
