Originally Posted by Christ
Easiest for you is an injector kill. There is a single power wire that feeds a resistor box, it's the only wire on the box that is a different color. The box is a finned aluminum case mounted on the drivers strut tower.
Switch inline with the different colored wire will kill power to all four injectors. This assumes you mean the CRX.
Well thatmay be the easiest but is it the best??.. And yes I mean my CRX
