In Alberta? Doubtful it will be messed with. If it makes you feel better a cheap security system could be set up to prevent the vehicle from being started. Include a back up battery to ensure it will work if the car's battery is disconnected. If you want to go really cheap, put a switch in line with the starter 12v+ wire.
