An O2 bung/3 wire sensor would be cheap. Using a multimeter you can tune your cruise pretty lean unless you are planning on towing a great deal.
Carburetor Tuning the Scientific Way
Good choice on the spreadbore carb. It can help the big pig get more reasonable mileage. The key with carbs is a very steady foot. Every time the pedal goes down the accelerator pump shoots additional gas.
