My xB has the following gear/rpm/speed relationship:
gear....rpm....speed
2nd.....1500..10 mph
2nd.....2500..20 mph
3rd......1500..15 mph
3rd......2500..30 mph
4th......1500..25 mph
4th......2500..40 mph
5th......1500..30 mph
5th......2500..50 mph
On flat ground, 1500 rpm to 2500 rpm is 3 seconds in 2nd gear, and 8 seconds in 3rd and 4th gears. I usually P&G at higher rpms in 5th gear, to accommodate highway speeds - typically 45-55 mph in the xB, but 50-65 mph in the SE-R. Those accelerations both take about 8 seconds. The times go up on uphills, and down on downhills. I suspect your high-revving GSR might like 1700-2800 rpm better, probably at the same rate of acceleration.
An Ultragauge or Scangauge will quickly pay for itself. I've saved over $1700 in 2-1/2 years compared to the EPA combined estimates.
I do a lot of EOC between pulses. Compared to the 3-8 second pulses, my glide times are typically 30 seconds 20-10 mph, 40 seconds 30-15 mph, 24 seconds 40-25 mph, and 16 seconds 55-45 mph.
I start gliding to stops 3-4 blocks before them, unlike most drivers who still have their feet on the gas pedal half a block from the stop. I also shut the engine off at all stops where I expect to be there more than 7 seconds.
So, my advice is slow down and conserve momentum.
I pass through Santa Barbara a couple of times/year, on the way to my parents' home near Ventura, and/or my son's in Camarillo. Perhaps we can coordinate a clinic, and/or I can loan you my Scangauge for a couple of days on one of those trips.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
Mean Green Toaster Machine
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
