Just remove the fuse for the fuel pump if it's easy to reach when the car is parked in an ''unsafe zone''
You could also use that technique on other fuses too!
There's another aproach, a 30-50w siren tucked under passenger seat. Siren will start with a time delay of 5-10sec once the car is started if you don't flip a switch. You'll be sure thief will leave the car there.
