Old 05-31-2011, 06:00 AM   #2 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
The grille? Upper and lower all face right into the radiator. Until I get more used to its temperature range I don't dare reduce it, especially going into summer.
Most of the cooling usually comes from the lower grille.
Do you have something like a ScanGauge so you can see the actual temperature, rather than the car's own temp meter ?
My 90% upper grille block increased water temps by only 3 - 5° C - invisible on the car's thermometer.
Find out what temp your thermostat opens at, temps should not go much higher than that - and not stay well above that for long.
With this underbody an air dam would just increase FA.
It could still work.
Air going underneath will still cause drag. You could still benefit from a moderate air dam - even though it will increase frontal area.
Try it, and see what it gives.
It sometimes moves with a sense of urgency.
LOL.
