Old 05-31-2011, 08:27 AM   #23 (permalink)
320touring
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
my 1988 320 has athe bmw m20b20 straight 6
the injectors fire in two banks of 3, and it has no knock sensor to advance/retard ignition.
Single cam with 256 degree duration (almost flat!) and a flathead setup on the combustion
Cd is 0.36 and it weighs in at 1325kg with a full tank
4.27 final drive (4000rpm at indicated 80mph)
38 UK mpg if lightly hypermiled 32 uk mpg if driven normally
on an engine that was designed in the 1960's and originally carb fed
thats 2 uk MPG less than the e36 iS I have
with its 1.8 litre m42b18 16v DOHC lump and Cd of 0.30
The 535i (m30b34) is a manual, and in limited testing so far, i've seen 30.3 uk mpg high and 12 uk mpg low..
My Blog on cars- Fu'Gutty Cars
http://fuguttycars.wordpress.com/
US MPG for my Renault Clio 182
