Well done on your progress, your numbers are looking good. If you feel confident then you should expand upon your use of EOC, the benefits add up very quickly. You might also like to consider some aero-mods, a grille block might be a good place to start as well as making sure that the front end is smooth, with no depressions sucking in air.
Spoken like a champion. Oh no, disaster!
