Thread: 1994 Ford F150
Old 05-31-2011, 03:08 PM   #14 (permalink)
Execut1ve
EcoLurker
Execut1ve's Avatar
truck - '94 Ford F150 XLT
90 day: 13.15 mpg (US)
civic - '00 Honda Civic EX
90 day: 36.24 mpg (US)
I must not have been clear, the engine is MAF not MAP. As far as exhaust I'm running no cats, downpipes into a y-pipe into a muffler to exit in front of the passenger rear wheel. Emission stuff (smog pump/thermactor system) has been removed from the engine as well.
I doubt I could get a 6 cyl engine in there cheaper than what I have planned, unless you have a truck w/ that engine and less than 30k mi that you can recommend for less than $500. I don't mind putting in the work, I'll be doing most of the wrench turning on this myself, so no labor cost.
FE isn't my only motivation for the steering conversion. These trucks are notorious for loud/inefficient power steering pumps, and I'm tired of hearing that pump whine. Also there is a lot of play in the steering, no doubt due to a worn gearbox, so there's a good chance swapping in a new gearbox will eliminate that problem.
