30s
His trans made it for 30 seconds of coasting down on the dyno with the engine off. He tore it down and found 5th gear welded to the shaft. All of the other dyno videos I have seen show the rider blipping the throttle of a running engine all the while as they slowly brake the drum in order to lube the trans. Coasting at idle with the clutch in is no problem.
