THANK YOU MR NASA !!!!!!
You STILL seem to be hooked up on Longer line theory or equal transit time being Benoulli law- IT ISN'T!!!!!
Benoulli IS required for flight
to quote
"Bernoulli’s law is derived from the conservation of energy. So in any flow problem, Newton’s laws and Bernoulli’s law are satisfied at the same time … they aren’t added together. "
I'm sorry if I seem a little het up about this maybe its because I too have a degree in Aeronautical engineeering and spent a ****load of time in a wind tunnel. but reading what he says is just dispelling Long line / ETT and not the fact that flight comes the principles of Benoullis law.
Next go to this Nasa link
http://www.grc.nasa.gov/WWW/K-12/airplane/foil3.html
and put in 0 degree angle of attack and mess with the camber and chord%
See what happens when you try a flat bottomed wing, -3.5deg AoA,8%camber, 11.5% chord thickness
a) flow lines (deceptive because they seem to show ETT) - but there is UPwash
b) lift generated (1239lbs)
