You did yourself a favor using the junkyard part. The aftermarket switches are garbage. Usually there is a 90 day(max) replacement warranty only. My sunfire went through about 4 switches before it got totalled. The headlights would go out and you could jiggle it to make them work. After wasting $70 at autozone, I got one used that was nearly worn out for $30, it lasted longer than the autozone part. After that I went to the pick and pull and got 2 for $20 each. It sounds like the sunfire switch was easier to replace.
