Old 06-01-2011, 06:40 PM   #278 (permalink)
ianbartie
VW Polo EV
Hi Chris
My setup is the same as your drawing. There was no movement of the needle at all. Stayed on empty even adjusting VR2.
I can see the pulses on TB1-10 on the scope when I bench test it but I haven't scoped it in the car. The duty changes between 100% or 20% on the bench.
I'll do that this morning & try the capacitor too. I'll also measure the current between full & empty using the variable resistors.
The sender wire definately is not driving a coil. The VW uses stepper motors in the gauges. The wiring diagram just shows the sender wire going into the mysterious 'dash panel'.
I have found during this conversion that if there was a simple way or a complicated way to do things, VW always choose the most complicated way.
Electric VW Polo
