Thread: crazy comments
Old 06-01-2011, 10:31 PM   #8 (permalink)
cleanspeed1
Diesel Addict/No Cure
cleanspeed1's Avatar
StolenHoopty - '90 Honda Accord EX
HvyDrnkr - '93 Cadillac Seville
L88 - 427ci / aluminum heads / cast iron block / 430hp / Corvette option, there were early and late versions, massively underated
LS6- 454ci / 450hp ( 460hp in the Vette ) Chevelle usually, but Yenko, Nickey, Baldwin-Motion would stick it in any chassis you wanted short of a Corvair.
LS7 - 454ci / want to say 460-465hp but I may have to look it up, not officially offered in a car from the factory but no doubt "found their way" into some and was a dealer aftermarket engine package.
221ci or 260ci for the Ford small block
Ford and Chevy made 427ci big block
Sunbeam Alpine Tiger
Toploader means that the gear assembly loads from the top of the transmission case
440 Magnum - Hi Po 440ci big block with 4 barrel, 268 degree cam, high perf heads, high flow exhaust manifolds; same basic package was used in pursuit package for police work ( '69s were legendary, those bricks would sail to 150 mph )
Volvo WIA42 VED-12 / 335 hp / 1300 ft/lbs / 9 mpg
Big n' Boxy, Never met a Hill it Didn't Like
