Originally Posted by roosterk0031
I wonder how healthy it is for your turbo to cut it's oil supply very often, does the car come with a system to provide cool down oil to the turbo? I know they are available aftermarket.
Are you referring to the Intercooler? If so yes there is one.
As a point of clarification, when you say cutting the oil to the turbo, do you mean by killing the fuel? Isn't the only difference on the engine between doing a EOC and just stopping the car and turning it off, that the car is in motion and can be used to bump start? Other than this, in both cases isn't the engine, and turbo off?
