Old 06-02-2011, 01:51 PM   #13 (permalink)
texanidiot25
texanidiot25's Avatar
Formula - '96 Firebird Formula/Trans-Am
90 day: 19.31 mpg (US)
Originally Posted by NHRABill View Post
changing the jets from stock may be a mistake. too small and the back bores may need to open sooner. Just play with the a/f screw if you think you can lean it make sure you keep a close eye on the temp gauge and look at your plugs listen for detonation and pinging.
2 things based on my experience with the Q-Jets:
-The secondaries main throttle blades are mechanical, opening around 70% throttle. It's only vacuum in the sense that the upper blades open with vacuum, but air is ultimately throttled by the main blades at the carb base.
-The tuning needles are idle air mixture screws, they won't effect the upper rpm range. Anything else and you'll have to play with jets and needles. You can adjust fuel curves with different needles.
Lets see how far it can go
"All I know about music is that not many people ever really hear it. [...] But the man who creates the music is hearing something else, is dealing with the roar rising from the void and imposing order on it as it hits the air. What is evoked in him, then, is of another order, more terrible because it has no words, and triumphant, too, for the same reason. And his triumph, when he triumphs, is ours." -Sonny's Blues
