Old 06-02-2011, 03:29 PM   #15 (permalink)
NHRABill
NHRABill's Avatar
Tahoe - '95 Chevrolet Tahoe LT
90 day: 13.22 mpg (US)
SRX - '04 Cadillac SRX AWD
XL - '05 Harley Davidson Sportster XL
90 day: 49.97 mpg (US)
Alero - '02 Oldsmobile Alero GLS
Corvette - '75 Chevrolet Corvette Stingray
Originally Posted by northboundtrain View Post
Thanks again for the input. I'm going to rebuild the Q-jet stock and just get the truck running, but ultimately, it would be nice to be able to adjust the air/fuel at cruising speed, based on the O2 and pyrometer readings. I've even thought of rigging a linkage to the dash so it can be done on the fly. What would be good candidates for a different carb that can be screw adjusted?
You could always toss on a 2bbl by swapping the manifold or getting a 2bbl carb adapter ... obvious as it is that what you are doing is opposite of what is popular and it should be very cheap. I sold a nice 2bbl carb manifold setup I had on my 68 camaro 327 for $75
good luck, looking forward to see what #'s you pull I will swap my truck to carb if the TBI ever gave me an issue.
2012 Chevrolet Traverse *active*
2002 Oldsmobile Alero GLS *active*
2002 S10 2wd p/u 139,000mi. *active*
1975 Corvette Stingray *active*
1994 Camaro Z28 Convertible 149k *Sold 2013*
1998 Blazer ZR2 189k *Sold 2012*
1995 Tahoe LT 250k *Sold 2011*
