Old 06-02-2011, 10:24 PM   #283 (permalink)
Freyguy
EV Builder
Freyguy's Avatar
Well, the low duty cycle sure explains why those average voltages you measured were so low
Looks to me like the computer periodically applies current to the sender/trim pot during ADC sampling. Could be through a transistor or other type of analog switch. May be part of a multiplexing arrangement due to single ADC.
One approach would be RC filter of PWM and buffer with an op amp. I’d avoid having the op-amp connected to sender wire directly. Using a series 71 ohm resistor, the op amp would need to output 0V for empty and approximately 2V for full.
Op-amp needs to be able to sink 14mA and could be powered from the 5V and GND available at TB1 positions 3 and 4 of the LCD brd. VR2 and PWM max still used to tune the empty/full range.
The TLV2472 used on the LCD brd would work. A single version is the TLV2471
-Chris
