Old 06-03-2011, 03:23 AM   #66 (permalink)
texanidiot25
texanidiot25's Avatar
Formula - '96 Firebird Formula/Trans-Am
90 day: 19.31 mpg (US)
Originally Posted by t vago View Post
Engine misfiring is never good. You may claim otherwise, but it's never a good thing to have completely unburnt fuel-air mix exit the combustion chamber. At best, you're just wasting fuel, and at worst, you're burning up your catalytic converter AND prematurely wearing out your piston rings due to fuel dilution of the engine oil clinging to the sides of the cylinder walls.
And how again do you propose to eliminate excessive NOx and unburnt hydrocarbon emissions with this DCD gadget?
Unless you pass one of them mobile emissions checking trailers. Or until your cat burns out from excess unburnt fuel. Or until your engine starts burning oil from worn-out piston rings due to fuel-diluted oil.
I think you're missing the point of the system. The "dead" cylinders' fuel injectors won't fire, there won't be unburnt fuel. Spraying fuel into the "dead" cylinders would defeat the purpose of the product. And from what I'm reading, it's tricks the ECU into fueling the working cylinders as normal, keeping afrs straight.
Just my 2 cents with out reading his entire article (Let me know if I've missed something, and fuel injectors still spray into cylinders with no spark), and based on what he's posted here.
Lets see how far it can go
"All I know about music is that not many people ever really hear it. [...] But the man who creates the music is hearing something else, is dealing with the roar rising from the void and imposing order on it as it hits the air. What is evoked in him, then, is of another order, more terrible because it has no words, and triumphant, too, for the same reason. And his triumph, when he triumphs, is ours." -Sonny's Blues
The Following 2 Users Say Thank You to texanidiot25 For This Useful Post:
Heihetech (06-04-2011), shovel (03-14-2012)
