Old 06-03-2011, 11:37 AM   #40 (permalink)
SentraSE-R
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
Thanks for the feedback so far. It's better to measure twice, and cut once. I fixed the 185/60-15 typos, and the 33/35 mph inconsistency.
I'll include highway testing. My test route is on a frontage road paralleling a freeway, so it's easy enough to add a freeway test.
I'll inflate all tires to the same inflation pressure, either 44 or 51 psi.
Does anybody know how long it takes to warm tires up? I was hoping since the start of the test drive is only 4 miles from home, that I could consider all the tires cold when starting the test. Then the only issue would be the final retest of the first set of tires, and they'll have had about 4 hours to cool down after their first run,
One problem is going to be ambient temperature and wind. I'll want to start the test early because vicious 30-40 mph crosswinds typically start up in the afternoon about 2-3 p.m. But if I start before 9 a.m., there'll be a 20 degree temperature change. Even starting at 9, there'll be a 10 degree change.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
