What you do with the kinetic energy you have at the top of an acceleration is more important than how you get up to speed. (Within reason, don't lug it and keep out of enrichment) If you can avoid the brakes you won't be wasting fuel used to accelerate.
I skip gears to get into 5th if a lower gear is not needed to get up to speed. Going up hill I go a little farther into the gear (let the engine rev a little higher) Going down hill I shift up sooner.
Instantaneous fuel consumption information is very key, an MPGuino or the like will help a great deal.
The method I use is to push the throttle in until the rate of acceleration stops increasing then back off a fraction.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
