Just be aware of the fact that the type of tire (meaning make and model) may have a pretty large effect on your results.
You'll also be changing tire size which will also have an effect. Not to mention removing worn out tires and replacing with new. So there are 3 variables just in tires. Be careful when you report the results that you don't identify a single item as the change in mpg!
