Originally Posted by Clev
Oh, excellent idea! Does doing this trigger the Check Engine light?
Based on the thread, I decided to wire my relay switch to the cam sensor. I have a '97 Geo Metro. It was quite easy actually. I thought it was so easy I must doing something wrong. Here's what I did.
I found the cam sensor wires by locating them at base of the distributor box. Mine had a white and black (if I remember right). I carefully removed the black protective casing and spliced the white wire carefully and tied the two open ends to two 18 gauge wires that I simply connected to a 12v, 20 amp black rocket (?) switch (less than $5) on my dash. It works fine and I haven't yet seen the check engine light come on. I used wire connectors and black electrical tape.
