Old 05-08-2008, 06:49 PM   #19 (permalink)
steensn
The Hulk - '96 Ford Aspire Base
90 day: 51.64 mpg (US)
Black Hole - '06 Kia Rio LX
90 day: 39.16 mpg (US)
Send a message via AIM to steensn
Originally Posted by esmith2039 View Post
That almost sounds like a waterpump. My alternator is going bad but the alt/battery light is coming on .
My first thought was that it was the water pump too, but luckely from my automotive experiance I was able to debug it a little farther. Basically I can make it sqeak by turning on or off electrical devices like lights and rear defrost and make it go away by turning them off.
If you want to get mad crazy with weight reduction a few other pieces hiding that can be removed. Would be at your risk though, I won't remove it on mine since my wife drives it. Under the front and rear bumper skins the bumper supports can be removed and just reinstall the skin, I want to say 20+ lbs a piece. But if you choose you design a more aerodynamic front end (shouldn't he hard to do). Could remove both airbags also, around 8+ lbs piece. Any lightweight Mazda steering wheel can be installed in it's place. Their's a debate if the 1st gen airbags are more harmful than good as that's what the Aspire's use (would never remove 2 gen in new cars though). Your risk though, your insurance wouldn't like it either. So there's around 60lbs plus any aerodynamic savings if you go that route.
I would never remove airbags, I work in the automotive safety area and would never remove these accept for the passenger seat because I am taking the seat out anyways. If I were to replace the steering wheel with the Mazda one, I would make sure the airbag setup would still work.
Just a few random thoughts.. don't know how they'd help with MPG. Could install a Honda battery instead of a regular size battery the Aspire uses. Probably 5-10lbs there (maybe more). Maybe add some heavier ground wires under the hood. They helped my last Aspire run better, I guess in theory you could say it helps the alternator out hence reduces its drag?
Good idea on the battery, I'm still tempted to take the spare tire out, but I don't wanna take the risk. I might do the wires, good idea at least to make it run better. I want to install an on off switch for stopping, but I do not want to do it until the car is running superb and all tuned up.
Some racing techniques can be applied to saving techniques just have to slow down rather than speed up.
Done and done, I'm applying my professional driving skills to get better gas mileage. I read the 100+ list and found I was doing a lot of it, but some of it just didn't go that far.
2006 Kia Rio
1996 Ford Aspire
