Old 06-05-2011, 01:36 PM   #2 (permalink)
Otto
Why not just add stiffeners to the coroplast? Insert dowel rods of correct thickness where needed. Probably lighter and quieter than masonite, and you already did the work.
Heat: Use aluminum window screen material, held taught, near exhaust pipe, etc.. The aluminum screen is a superb heat conductor/dissipater, also breathes to let heat out while maintaining a relatively smooth aerodynamic surface.
