Formula - '96 Firebird Formula/Trans-Am 90 day: 19.31 mpg (US)
Auto Charge Voltage Stabilizer Fuel Saver
![](http://www.eobdii.com/media//3517001d.jpg)
Importance of Car Electronics and Stability of In-Car Voltage
Do you know how important is electrical voltage to your car performance and life-span? Many problems occurred in your car now are due to unstable voltage supply, and if your car is not taken care of ASAP, it will then worsen to serious problem later. Most of the car owners look for mechanics assistance when having problems with their cars from time to time. They are unable to find the right cause and remedy to the problems, and worst of all, car owners have to compromise to the problems most of the time. As we know "precaution is better then treatment", like we take good care of our body, we should take good care of our car before it is too late. Small spending in advance is definitely a wise investment, as it has very high cost/performance in returns.
Electrical systems in our cars are interconnected to each other. To get perfect performance you need a good and harmony electrical circuit environment. For example, if you have a old and less efficient ignition circuit in your car, you will have very poor fuel consumption, low throttle response, misfiring problem, jerking gear shift, all problems may occurred due to a single defect in another electrical problem. So to maintain optimum electrical performance in your car, we need to have a very stable voltage environment. Here comes a new electronic device ?AUTO-CHARGE, original patent/copyright from Japan, a multi-purpose Voltage Stabilizer with built in Battery Doctor System and Interference Reducer System. Once you use AUTO-CHARGE, your car is in best control by this product, it will solve small problems that due to unstable voltage during driving. What is more wonderful, it is so easy to installed, with just a plug into cigar-lighter socket, will activate this device. Unlike other fuel saving product, by adding chemical and tablets into the fuel tank, increase the risk of car damages.
The real gem however, is this right here:
2. How does AUTO-CHARGE help my car? What benefits I can earn from using it?
The 3 Systems in AUTO-CHARGE help your car working at its optimum condition. Voltage Stabilizer System (VSS) is designed to maintain a stable working voltage over all electronic circuits and devices in your car. When there is an extra sudden load on your vehicle, like acceleration or turning on air-condition, it will prevent that load drain away any current from another electronic circuit in your car and all electrical parts will be working at their optimum conditions. Battery Doctor System (BDS) is a new great circuit that helps all car owners to check their batteries operating voltage without opening cars engine hood. Even lady drivers can use this system to monitor battery condition easily. Interference Reducer System (IRS) is incorporated to reduce noise interference in your car so to eliminate unwanted electrical signal from one device to another. Now, most of new cars use a lot of electronic parts, and it is like human body, it has actuators (similar to our hands autonomic nerves) and reflectors (to our hands moto nerves system), signal are caught by actuators (like knock sensor) send back to CPU and process, new data is sent back to reflector (like spark plug) to correct problems. Noise interference will affect the accuracy of your car CPU computer response, so IRS will filter all noise signals and offer a low-noise signal operating condition to allow more accurate signal transfer between actuator and reflector for better car performance.
Lets see how far it can go
"All I know about music is that not many people ever really hear it. [...] But the man who creates the music is hearing something else, is dealing with the roar rising from the void and imposing order on it as it hits the air. What is evoked in him, then, is of another order, more terrible because it has no words, and triumphant, too, for the same reason. And his triumph, when he triumphs, is ours." -Sonny's Blues
