Old 06-05-2011, 11:23 PM   #2 (permalink)
Joenavy85
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
couldn't tell you the RPM's to shift at, the last time i owned a honda it was turbocharged and i made good use of it. as far as the shift from neutral to 3rd (or whatever gear you're going to) make sure you "blip" the throttle to raise engine RPM prior to engaging the clutch (a process called "rev matching") it could take some time to figure out exactly how high you want to rev your engine prior to engaging the clutch, it's all practice.
