Old 06-06-2011, 03:58 AM   #308 (permalink)
mora
Golfwagen - '89 Volkswagen Golf mk2
90 day: 107.14 mpg (US)
Originally Posted by Freyguy View Post
The capacity value in EEPROM by default after programming is 115Ahrs(my batteries). If your capacity is larger then this, then yes it will initially show >100%. After programming, you should do an SOC reset. This will reset to 100% and use your capacity values to overwrite mine in EEPROM
Yes, I did a SOC reset. I have 90Ah cells and I set capacity parameters to 04 (high) and F1 (mid). (3 bytes/24 bits: 00000100 11110001 00000000). If I understood right this should be 89.95Ah (or 323 840 As). I set pmile to 17 and at 124% SOC I got 49 KTE, which is 80% of 61km. When SOC is "reduced" to 100% KTE also lowers.
I must have missed cougarLCD_Config_Rev_1_3.pdf when browsing wiki as it has lots of useful info regarding setup.
