This should help to interpret the results.
For the HC being higher.
Measured in PPM (parts per million), this is the result of unburned fuel making it out the tailpipe. This is different from the CO problem in that here the fuel has not started combustion at all. This failure is usually caused by an ignition (misfire), or an engine problem such as a bad valve. An engine running too lean will often have excessive HC due to what is called a "lean misfire". Any leaks in the intake system or bad injectors will also cause excessive HC due to uneven fuel distribution.
I think those are great results.
"Judge a person by their questions rather than their answers."
Reason: HC
