Originally Posted by Promising_Confinement
In the past before I got the phone and the app just keeping track of it myself, with REALLY trying ... doing things like on the way out to where I deliver the papers ... speeding up to about 60, keep my foot on the clutch, turn the car off -leaving it on accessory-, coasting down to about 45, pop the clutch, speed back up, rinse repeat and doing that as often as I can on the route itself. Something I would NEVER try during the day, but at 3 or 4 in the morning with barley any traffic at all it's not such a big deal. heh
Something to keep in mind, by just releasing the clutch at 45ish your engine is instantly going from 0 rpm to about 1800. It is also doing this before the oil pressure has an opportunity to build up. This may have a negative effect on the life of your bearings and what not. One thing you can do is release the clutch just a enough to get the engine spinning then press it back in while it stabilizes at idle. Then release the clutch and start accelerating again. If you are doing it right a full glass of water sitting on the dash would not be disturbed while bump starting (I wish I was always that smooth
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
