Originally Posted by robchalmers
Warbling getting worse and it was getting hard to select gears - Its currentyl in getting a 'box oil change while I'm at work...
I'm not crossing my fingers anymore, my pesimist side has won the day!
If the car is still mobile on thursday at 6am I'll be very surprised - even then will it be able to do nearly 600miles in two legs?
Is it a cable operated clutch or a hydraulic one? could it have the old Mk 1 golf issue of bulkhead being pulled apart by cable movement?
Its a diesel- just lock the box in 4th and off you go
