Old 06-07-2011, 01:10 PM   #14 (permalink)
bwilson4web
Engineering first
bwilson4web's Avatar
17 i3-REx - '14 BMW i3-REx
Last 3: 45.67 mpg (US)
Blue Bob's - '19 Tesla Std Rng Plus
Actually I had thought about a 5th wheel or trailer setup to measure tire rolling resistance. I saw a photo where the test tire was on a towed trailer with force sensors. My thinking is the trailer with 4-lug and 5-lug configuration would allow testing of 14", 15" and 17" wheels and hauling the unit to GreenDriveExpo. Then we could survey any tires that anyone wants to 'loan' for testing.
The other thought is to rig up a 4-wheel, multi-zone, IR thermal setup so we could measure temperature distributions across each tire tread, three are all that are needed. Then offer it as a free, dynamic alignment check with EZ-shim or metal tab shims available at cost to support 4-wheel alignment. In the meanwhile, collecting the ratio of tire temperatures to road and air temperatures would give a good, 1st order metric of relative rolling resistance. Same idea as before, offer it at GreenDriveExpo.
I like the second approach because no tire changing is involved which will speed up data collection. Best of all, the owner gets useful information that they can follow-up with if they want to optimize their alignment. Everybody wins.
As for the transaxle testing, I'm really interested in the relative transaxle oil effects and the study cited earlier has loss curves that show an exponential curve. I should be able to use the viscosity formula to make a parametric set to understand what is the likely effect, the magnitude. Then do a couple of point-measurements to apply to the curves and voila, a practical transaxle friction/viscosity loss model.
As for the measurements, I really want to avoid hill rolling in this case as I think I can get better data with known drive and load forces.
Bob Wilson
2019 Tesla Model 3 Std. Range Plus - 215 mi EV
2017 BMW i3-REx - 106 mi EV, 88 mi mid-grade
Retired engineer, Huntsville, AL
