Old 06-07-2011, 04:59 PM   #22 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
here is the homepage, scroll down to "the quad"
K-Man Auto & Scooters
Engine type: 150cc GY6 engine, fully automatic, single cylinder, 4-stroke, forced
air-cooled
Engine displacement (ml): 149.6
Bore x stroke (mm): 57.4 * 57.8
Max. power (Kw/r/min):8.0/8000
Max. toque (N.m/r/min):9.0/5500
Fuel tank capacity:7L
Fuel consumption (g/kWh): 367
Start mode: electric start
Tires (front/rear):12 x 3.5-10
Transmission mode: chain
Brake mode(front/rear): dual hydraulic disc / hydraulic disc
Shift speed type: CVT
Suspension(front/rear):independent double hydraulic shock/ hydraulic shock
Length x width x height (mm): 1710x700x750
Seat height (mm): 530
Top speed (km/h): 100
Colors: silver+plating black+plating
18)Max. load: 100kg
Packing:
Carton dimensions: 176x 50 x 68cm
N.W.:/G.W.: 125kg/135kg
I think "why" is a reasonable question
They call out the vehicle below it as street legal (The SuperTrike), but they didn't with the quad, go figure.
