I have not decided whether to go ac or dc. Regen is not a big consideration but drag with the motor turned off is. If I do not use regen I could use a sprag so the motor would not spin on longer trips. Would prefer using available products. Don't want to make it too complicated. Budget has to be reasonable, just because it may or may not provide a big mpg improvement.
