Old 06-09-2011, 02:14 PM   #1 (permalink)
Hauki
Hauki's Avatar
Scudo - '98 Fiat Scudo (van) 1.9 TD
90 day: 40.94 mpg (US)
My tyres were oversized my MPG went down!
So I had my winter tyres on when I started monitoring my FE. I was getting pretty good fuel figures without really trying too hard. No aero mods and a little P&G would get me way above book figure (or EPA as you would say?).
Anyway, I have since realised the winter tyres were 195/65 15" and my car should have 195/55 15" fitted!!! This has made all my fuel readings void! (I go by in car computer not actually tank range).
Last week I get a new set of 18" alloys with 215/35 Summer Tyres, which is pretty much the exact same rolling radius as the standard 195/55 15's. All of a sudden I have lost about 5 MPG!!
Panic sets in! Now obviously, I haven't *actually* lost fuel, but the onboard computer has been reporting incorrectly due to larger rolling radius. But it is still alarming when you are used to seeing 40+ on the computer suddenly drop to mid 30's!
So I had the task of getting the MPG 'readout' back up to the figures I was used to seeing.
Today I put a lower grille block on, nothing fancy, but it does the job. It is 29°C this week and my car ran 2°C hotter which is good because motonet (auto shop) sent me the wrong thermostat when my old one failed and this one runs 2 degrees cooler. So that has brought my thermostat up to standard temp! And I also adjusted toe-in as one wheel was way out and the other was slightly out.
Then I went to garage on nearest island which has an air pump guage. The new tyres should be 50 PSI. I checked all 4 - below 30PSI! The drive there I stuggled to get 38 MPG (UK) (ok I didn't P&G I had a ferry to catch), the drive back I got 47 with a bit (and I mean a bit) of P&G
I know the old cliché about tyres being pumped up properly, but jesus christ, what a difference, maybe because I have low profile tyres they scrub even worse deflated I don't know.
So now I am pretty much back to the readings I was getting with my oversize winter tyres, only now my readings are true!
I really need to get some polycarbonate to cover the lower grille and fogs properly, I think this is pretty bad area that needs adressing. Here is a pic of same model as mine, see the lower grille and fogs is a gaping hole:
. My grille block sits in the centre hole quite a way back, so air is still entering it and then hitting the block, I could really do with something flush just below the license plate down to the front splitter. I think this would be significant improvement
*Note that aint my car (exact same year and model (and wheels)) but mine car looks like an off roader it sits so high!
Goal: 5 L/100 km
Currently:
Car Spares
