Old 06-09-2011, 04:15 PM   #6 (permalink)
Ford Man
Originally Posted by iskyfly View Post
sorry for intruding- however, i thought the correct tire pressure should be what is on the sticker on the door frame, NOT what the sidewall reads.
in other words, correct tire pressue is vehicle dependant.
Most car manufacturers recommend lower tire pressure for comfort (softer ride). I'm running 50 psi in my tires, I think the door placard states either 30 or 32 psi. It does give the car a little bit of harsher ride, but the handling of the car has improved and my tires seem to last longer with the higher pressure.
