Old 06-10-2011, 01:14 PM   #3 (permalink)
cleanspeed1
Diesel Addict/No Cure
cleanspeed1's Avatar
StolenHoopty - '90 Honda Accord EX
HvyDrnkr - '93 Cadillac Seville
Let's take a look at the differences between the 4.6 Modular ( 2V ) and the 5.0 Ford.
Reduced bore for lower emissions
Low fiction valvetrain
Low friction piston rings
Undersquare bore to stroke ratio
Fast burn combustion chambers, small valves and ports for high velocity
Long runner intake manifold
For economy, the closer you can keep it to stock, the better it will run because it was optimized from the factory to run in the lower ranges most of the time. Anything that enlarges the ports lowers the velocity of air into the port at lower rpms, unless there's a displacement increase or some form of supercharging. Headers are not bad if they are built for no compromise in tube size and length, along with collector dimensions.
Cam timing, overall tune and gearing are the arbiters.
Volvo WIA42 VED-12 / 335 hp / 1300 ft/lbs / 9 mpg
Big n' Boxy, Never met a Hill it Didn't Like
