OK, then balance and blueprint the engine to death, barrier coat the pistons, Total Seal Gapless piston rings, degreed stock cam or find a core to regrind for more torque, valve job to boost the low to mid lift flow, mild cleanup on the head, match everything.
Find a gearset that will slow the engine down.
Volvo WIA42 VED-12 / 335 hp / 1300 ft/lbs / 9 mpg
Big n' Boxy, Never met a Hill it Didn't Like
